All credit to whoever thought of this.
Take the wheel off, then undo the top ball joint nut, take off the anti-roll bar nut, then remove the three other bolts that hold the lower arm to the chassis. Took the arm off, used a socket and three ton press to push out the old ball joint, pressed the new joint in, put it back on the car, zipped all the nuts up with the air gun, job done!
I didn't have any welds or anything to contend with, the ball joints are just pushed in to the arm and secured with a c-clip. You could easily do the job with just a big hammer, vise and a socket set.
