its on driverside just behind the downpipe, will be tight though so dont drain the oil untill youve managed to loosen the fillerplug.
its a square plug which i think is 3/8
no mate the e brake is off and car is out of gear, just checked and the transfer box has locked itself due to no oil. so will be needing a transfer box
well the way i checked was i bolted the rear diff off and it was locked from the part the prop shaft goes into the front diff. thats why i will be getting another transfer box
