I'm trying to run a wire from the engine bay to my AFR gauge.
There's already a boost pipe for the boost gauge run through a rubber grommet just up from the accelerator pedal - but no matter how I try I cannot get this wire to appear on the other side. I've tried from the engine bay and from inside.
Now I'm fed up of being upside down in the footwell :roll:
I thought about running the signal wire to the wiring on the ecu but that looks fiddly as hell to get out.
Would it help to remove the inner wheel arch? Can you access the cable runs by doing that?
GeeTee 8)
GeeTee 8)
