scoobkiller
anyone got a how to as bit stuck.. got a fmic and turbo housing needs turning a bit to line it up propaly..
aaaarrrrggghhhh help please
Just loosened so it releases the clamping pressure. How much do you need to rotate the inlet housing. I had to custom fit my actuator on my turbo cos i had to turn the inlet housing so much.standard tub's
and started undoing them but actuator is joined to a few of the bolts..
and do they need to be fully out or just un-done
I had to cut my pipe to the topmount to twist the mounting point and space it out as my new turbo sat slightly lower. I connected back together with a radiator pipe from a digger.cheers mate,, nice diagram..
its compreser housing that needs to be turned.. might just cut pipe and re weld it so dont have to piss about,,
Isn't this what you're looking for?Torque Values for bolts
Compressor (GT series) 145-165 in-lbs
Turbine (GT series) 185-215 in-lbs"
have fun
Steve
