DRC
Hi. im running kent gtir cams (NGTi02)and hks ajustable pullies i have a very iratic idle some times it will sit at 1700rpm other times 900rpm then when it has ben run for a bit it will fluctuate between 800 and 2000rpm. im still bedding in the engine but it is driving me mad. The cams are set at zero degrees. just wondered if anyone knew the best angle to set them and if any one has come across this problem before?.
Does it make a difference if the bottem end has been lightend (light flywheel fitted) ?. (the ecu and all engine managment devices are standard).
