Idle speed
turbazz
Right feel like am really getting somewhere with my car now boost leak sorted and det sensor changed.
Next job to tackle is the idle speed.
The result I was getting before sensor change( det)
Cold....1500rpm
Slightly warm ....1000rpm
Up to temperature. 1500rpm
And now
1500
1000
1250
I'm not sure if this is normal? I get the feeling the last figure should be under thousand?
So where do i start?
It should be ~950rpm once at temperature, but it should fast idle for a minute or so before it settles-down (maybe 1250rpm).
I'll see if I can't find the official figures in the service manual.
EDIT: 850±50rpm for the SR20DET with the TPS disconnected, and 925±50 (actually +25 -75) with the TPS connected? - I can't find what the fast idle should be.
Anyway...
Diagnostic procedure 1 - High Idle After Warmup:
  • Check air regulator. - Does pinching the hose cause the revs to drop?
    Try all the hoses because I found it was the dump valve leaking under vacuum at idle on mine.
  • Check intake for air leaks.
  • Check throttle linkage.
Diagnostic procedure 2 - Hunting:
  • Check lambda sensor.
  • Check injectors (they should all cause a drop in revs when you disconnect them).
  • Check spark plugs.
  • Check for air intake leaks.
Diagnostic procedure 3 - Unstable Idle:
  • Check injectors.
  • Check fuel pressure.
  • Check air intake for leaks.
  • Check idle screw for clogging. - I usually just take it out and give the whole IAC valve a blast of throttle body cleaner.
  • Check compression.
  • Check ECU.
Is that any help to be getting on with?
turbazz
Yes i need to do diagnostic procedure one?
What about the idle screw ias?
also I was going to do my ignition timing should I resolve this problem prior to doing so
turbazz
what is the air regulator and where is the throttle linkage how should I check this
