gtir bean
i was just trying to set my timing as it says in the how to guide and when i was setting it to about +19 the timing would advance to about +38?iwhen i retarded the dizzy about as far as i could it would take it back to about +20 but would get knocked right back by the ecu i would imagine and the rpm would drop.after this i would set it to +19 again and sometimes the timing would jump to +38 or so again and the rpm would jump up.is there a set rpm that the timing is advanced by the ecu?what should the timing be at idle when the tps is connected?mine is about +10,i think i got it set eventualy but im not sure.it does seem to pull smoother now than before,it was about +13 before i done anything.
