Drc said:
Just wanted to get general thoughts to these cams? . Also wondered if anyone else was running them?. As i was wondering if i should drop them for something less wild ?
(plus i cant get the dam thing to hold a stabble idle ! nor can the "pros" i sent the car to!). :?
so what i can gather is you run these cams in your sr20det yes?
what is the valve overlap duration? this would be the major cause of idle problems, and even the pros cant fix it without changing your cam profile
if it is huge, ie greater than 30 deg, piss em off for cams which give you less overlap but still the same open duration for intake and exhaust
