I have had code 34 since i bought it, seems to drive fine and runs about 9 PSI.
Have changed the knock sensor for a bosch one and Knock lite from Thor racing I also rewired it back to the ecu with a new plug, turn the ignition only on it shows 55 as soon as you start it and rev the engine (without even moving i.e no load) it shows 34 again. It is obviously picking some noise up but could it just be engine noise? if so how can I check?
With the new sensor fitted it is acting the same as before so I wired the old sensor in and did the same test with the old sensor wired up but sitting in the foot-well it didnt detect any knock.
Any ideas would be appreciated especially on how to measure what the sensor is detecting.
