the knocklink knock sesnor looks the same as a nissan and gm sensor.
and i will be connecting my knocklink sesnor to my factory niissan sensor and share the signal rather than fitting 2 sesnors,and im 99.99% that it will work ,as they work in the same way as i have said,
even the connectors that fit both sesnors are the same,and made by the same company also,i work in the motor trade ,and its very common for car companies to use the same sensors,its cheaper for them to build cars that way etc
also the fuel tank sesnors read the same resistance as a gm sender unit?
all makes sense to me ,
me and muppet fitted an aftermarket 3 wire oxygen sensor in his R and it works fine,as 99% of them work in the same way also
ROBERT
