Lambda sensor question.
C
Crazy
I am waiting for my Autometer air/Fuel gauge to arrive and will be fitting it at the weekend.
I have just had a look at the How To and it looks like a simple job but I am not keen on cutting into any wires that are near to the ECU due to trying this on a previous car and really fukcing it up so I going to take the live/negative from the usual place but I want to cut into the wires coming from my lambda sensor but I do not know which wire is the signal wire and that is where you guys can help :wink:
Which wire on the lambda sensor is the signal wire 8) :!:
Sirnixalot
the wires on the lambda arent usually copper. I am pretty sure they are aluminum...which you cant solder.
Just get a vampire tap.
