Down to the car, but no reason why it should. I've passed 1st time with a full Goose decat for the last 4-5 years.kenan said:as I assume the car will fail the mot without a cat on.
Where would I find this plug? is it under the carpetsnoon said:If you end up cutting the wire off the heat sensor, make sure you also unplug the wire under the drivers seat.
I didn't and it kept going into safe mode.
The plug under the carpet not the one under the seat.snoon said:If you end up cutting the wire off the heat sensor, make sure you also unplug the wire under the drivers seat.
Shaun
Shaun
That will be for the seat belt light.geoff pine said:Yes the seat one is some thing else
Depends on how it was cut. If the wires earth out on the metal work then that's why it goes into "safe mode".EssexAaron said:my cars Never went into safe mode since ive cut mine, it aint unplugged either
