warringtonjack
Low Oil Pressure - Problem Solved
Since putting new engine in, the oil pressure has always been low. From start, pressure is as low as 10psi, then slowly picks up after 15-20 secs to about 20psi. The pressure does rise with revs up to about 2bar. The pressures were recorded on a specialist gauge, so can discount the sender unit.
Anybody got any comments, as I know the pressure is way too low to be safe.
