Does this DP manifold below use the standard nissan gasket where you bolt the turbo on with the 4 bolts?
I've got to remove it as Mr Bodger who had the car before me didn't brace t properly on the engine block which in turn has put pressure on the external waste gate pipe and cracked the weld all round!
I don't get some people, all it needed was a single bolt putting in to brace it correctly!
