gazgstar
Ok so engine all run in now and I decided today to get some good oil in the car. Car had been running perfectly while running in then after changing the oil I decided to tidy up some of the vacums around the dump valve which resulted in distubing the maf, which then came up on the fault codes. When I sorted that out and cleared the codes I took it for I run and quickly noticed I had a miss from 1.5k to 3k that made the car really ruff on pick up...a lot of stuttering. I have checked all the wiring on it, all vacums and connections, tried another coil and I have no fault codes appearing, any ideas??
