Ngk plugs?
str_motorsport
i have a set of denso iridium ik 27 for sale.
only 500km
20 delivered
OZ-Racing
stugtir said:
http://www.sparkplugs.co.uk/
BKR9EIX ngk iridiums :wink:
i there under 40 quid delivered
stu
It said BKR7EIX when I did the search, did you make a mistake Stu, or did I fcuk up :?
I take it the Iridium plugs are better than the "Standard / Platinum" plugs, even though they are cheaper?
I
Innovate Performance
ShayneG said:
On that site they only list the sunny from 92 onwards. Mines a 91 will they still fit the same :?: :roll:
YES :D
Dooie Pop Pop
nismoboy said:
They just have a different heat range, select which heat range u need for the amount of boost u use.
you cant. its just listed as an alternative to the platnium, heat range not mentioned either
GINGA
Will need a different heat range to the standard plugs car I should have been more specific in the first place :oops: will be running 1.4bar+ and around 350hp i've got hks s40's in at the moment which should be fine but I wish to change them for the ngk equivalent of them anybody know what that is :?:
I've heard that ngk R's (I think) from cossies are supposed to be exellent and will fit the R :?:
I
Then you want these NGK Iridium Plugs x 4 - £ 47.00 ( Heat Range 8 ). Inc delivery. :D
