nissan oe water pump
micra man
hi lads , anyone got the part number for oe waterpump and gasket
the moron at nissan wants engine code frame code chassis number and still cant sort it out, what a complete and utter fool:roll: :roll:
anyone ?
cheers:thumbsup:
If you tried looking in the right bl00dy section in the post that say PART NUMBERS you may of found what you are after with out wasting our time looking it up for you, You dumb ass :doh: .
PUMP-WATER ASSY _______21010-54C00
If you have a local motor factor that stocks Blueprint parts, get one from them. I did and it was a fair bit cheaper from memory and, you can see where they had ground off the 'Nissan' emboss !! :)
antgtir
As you seem to have been given the part number i will just add my useless comment....................change Nissan Dealer lol ;-)
Ant.
azboy said:
no gasket m8 for it just sealer
With my Blueprint part, I did get a paper gasket but, I used high temp silicon sealant instead, seeing as the original one was fitted in the same way !
