GTI-R Kid
Might sound like a strange question, but since I've never seen it asked, mentioned or referred to I thought I'd bite the bullet.
Whats the story with doing an oil change when you have an oil cooler fitted? Is there any way to ensure that all the old oil is out of the system? I'm guessing that the oil only ever flows through the cooler when the engine is running and the oil pump is pushing the oil around the system - so does this not mean that when the engine is off there is some oil left in the cooler and cooler lines?
Is it just a case of replacing all you can from the sump and living with the fact that every time you do an oil change, there'll always be whatever volume of oil the cooler and lines hold that won't be replaced?
