jus want to check the to original speaker size for the front is 6.5" cus i got 2 different size speakers in my doors and neither of them are 6.5 inch. ????
The standard size are neither 505" or 6.5" but, some funny size no decent audio manufacturer makes.
The best fit for the door speakers would be 6.5" (17cm) but, they'll require mounting rings to get a decent seal against the door.
Of course, if you'd have used the search facility, you would have found that for yourself. :doh:
I had same problem recently trying to find speakers to fit. Ended up making an adapter plate out of MDF to suit the door and then mounted a set of speakers into them
