Carl Hammond
Well After the meet on Sunday in Maidstone, I noticed a prob on my car, Mike (AKA EX GTI-R) Has been kind enough to help but just wondering if anyone has any other idea's / opinions on the prob, mike is coming ronud later to check again and help further but the more help the better.
Prob happened when I noticed the car's fan belt squeeling and well loads of blue looking smoke came out through the vents. I pulled over and popped the bonnet and well the header tank was overflowoing onto the belt.... The temp gauge did not show over half although the car seemed to over heat... Anyway turned off and check connections and fuses as fans had not cut in and tried to drive home as not far away. About 1 min down the road the heat gauge read towards the H so pulled over and turned car off for safety reasons, RAC bloke turned up and said water pump may have gone, Mike being the good lad he is said that seems the thermostat jammed as the bottom water pipe on passenger side was cold. He came and took it out and well after a few checks the car stopped over heating and well the fans started working.
He has ordered me a new thermostat and is fitting this when I get back from holiday in a week but tonight we are testing the car with the orig thermostat that seems to be working when used in / over a kettle now.... If this does work and th4e car does not over heat again is this the only prob?
ANYONE ELSE FACED THIS OR NOT, If not anyone know how much a water pump is and where to get one asap...
I trust mike and hope it is just the thermostat so once the new one arrives we can fit it and all will be ok again..
Any advise will be great cheers lads... I am on 07766111627 if anyone has any info they could provide me with as I am new to this car....
