creedy
overheating the oil and water temp gauges both off the scale, but the water 1 drops now and then. then just shoots up again.
changed the water pump just now and the thermostat, also fitted a samco caus the bottom rad hose had a split in it from the heat. but i all ready have a uprated ally rad.
no white smoke or loss of power from engine so im not sure if its head gasket plus it has a 1.2mm metal 1 anyway.
there is steam coming from expansion tank and also if u crack the rad cap.
any know wot else it could be?
