my r is overheating badly, im seeing water temps of 110 degrees and oil temps of 110 also, Only thing i found was the bottom rad hose was rock hard!
I removed my thermostat and tested it and that works fine, i also done a compression test to see if the head gasket had gone but its fine.
Only things i can think of is either water pump? or my rad cap which is a 20psi one.
Is 20 psi to high for a rad cap? whats pressure rad caps do u all use?
also how do u test/check to see if the water pump is ok?
Any help on this would be much appreciated.cheers nis.
