I've said it before and I'm sure I'll say it again. I really do rate Greenstuff pads. They are a vast step up from the stock pads with regard to fade. Bite on the Pulsar is perhaps a little better than stock and of course they produce far less brake dust. The diasadvantage is much shorter pad life.
I run Greenstuff on my bike and used to run them on my 205 (very good on the 205). My brother also runs them on his Tipo and AX GT.
As a side point I'm going to try a set of Ferrodo's to see what they are like because they are cheap and will hopefully last a bit longer (I have slotted/drilled standard size discs).
In the past I haven't been too impressed by Mintex (for the price) but that was a few years ago. Others like them alot so...
Main thing is that the R brakes are pretty poor at the best of times so don't expect too much from a new set of pads.
Well, I run greenstuff on the front with brembo grooved discs and they do
work but they dont last it also depends on the disc and if you are on a track or not, I certainly wouldn't put them up against pagid or mintex 1144
they are much better
Frank
I was informed by an aftermarket parts supplier that green stuff pads, and he winked at this point , are not uprated. I wasn't inpressed with them. I've got Mintex 1144's to go with my new Brembo's
