As copied from Gti-r spares section (thanks Gary , also fastguy,kevgti-r and Davidgtir for already adding some )
FUEL FILTER______ 16400 53J10 £10.20
OIL FILTER ______15208 70J00 £5.20
WASHER,DRAIN ______11026 01M02 £1.10
HT LEADS 22450 54C27 ______£42.00
REPAIR KIT DUST(p/s front hub side)_______39241 63Y25 £22.00
RADIATOR ASSY _______21410 66Y01 £189(thin)
RADIATOR ASSY_______ 21410-63C00 £???(thick)
ROTOR,HEAD _______22157 54C01 £6.40
CAP,DISTRIBUTOR_______ 22162 53J00 £15.40
PUMP-WATER ASSY _______21010-54C00 £41.00?
LAMBDA SENSOR________ 22690-54C00 £86.00?
GASKET-ROCKER C ________13270 53J05 £7.20
GASKET-TURBO CH________ 14445 26E00 £15.20
GASKET-EXHAUST ________20691 58E01 £2.90
GASKET ________14415 17M00 £11.70
GEARBOX OIL SEAL ________38342 56E00 £5.20
TRANSFERBOX OIL SEAL___________ 33111-56E00 £7.90
COIL LEAD__________ 22450-53J11 £12.40
ROTOR ARM___________ 22157 54CO1 £ 6.40 +vat
CV BOOT KIT(FRONT)___39241 63Y25 £21.50 +vat
AIR FILTER____________16546 3J400 £10.40 +vat
SERV MAN VOL1 (ENG)____SM1E1N4BGO £84.60 (RARE AS ROCKING HORSE SH*T) +vat
SERV MAN VOL2________SM1E2N4BGO £66.60 +vat
HAND BRAKE SWITCH____36011 50Y00 £ 7.20 +vat
FUEL CABLE THING______H4659 50A05 £ 9.70 +vat (RELEASE MECHANISM IN BOOT)
DISTRIBUTOR POWER TRANSISTOR _______22020 53J10 £48 +VAT
IDLE AIR CONTROL VALVE AIR REGULATOR (BOLTED ONTO THE CYLINDER HEAD UNDER THE I.A.C.V WITH A BLACK SIDE TO IT) _______22660-93L00 £85.30+VAT
Please Add any that you may know
