FUEL FILTER______ 16400 53J10 £10.20
OIL FILTER ______15208 70J00 £5.20
WASHER,DRAIN ______11026 01M02 £1.10
HT LEADS 22450 54C27 ______£42.00
REPAIR KIT DUST(p/s front hub side)_______39241 63Y25 £22.00
RADIATOR ASSY _______21410 66Y01 £189(thin)
RADIATOR ASSY_______ 21410-63C00 £???(thick)
ROTOR,HEAD _______22157 54C01 £6.40
CAP,DISTRIBUTOR_______ 22162 53J00 £15.40
PUMP-WATER ASSY _______21010-54C00 £41.00?
LAMBDA SENSOR________ 22690-54C00 £86.00?
GASKET-ROCKER C ________13270 53J05 £7.20
GASKET-TURBO CH________ 14445 26E00 £15.20
GASKET-EXHAUST ________20691 58E01 £2.90
GASKET ________14415 17M00 £11.70
GEARBOX OIL SEAL ________38342 56E00 £5.20
TRANSFERBOX OIL SEAL___________ 33111-56E00 £7.90
COIL LEAD__________ 22450-53J11 £12.40
ROTOR ARM___________ 22157 54CO1 £ 6.40 +vat
CV BOOT KIT(FRONT)___39241 63Y25 £21.50 +vat
AIR FILTER____________16546 3J400 £10.40 +vat
SERV MAN VOL1 (ENG)____SM1E1N4BGO £84.60 (RARE AS ROCKING HORSE SH*T) +vat
SERV MAN VOL2________SM1E2N4BGO £66.60 +vat
HAND BRAKE SWITCH____36011 50Y00 £ 7.20 +vat
FUEL CABLE THING______H4659 50A05 £ 9.70 +vat (RELEASE MECHANISM IN BOOT)
DISTRIBUTOR POWER TRANSISTOR _______22020 53J10 £48 +VAT
IDLE AIR CONTROL VALVE AIR REGULATOR (BOLTED ONTO THE CYLINDER HEAD UNDER THE I.A.C.V WITH A BLACK SIDE TO IT) _______22660-93L00 £85.30+VAT
STRUT KIT-FRONT SUSPENSION, RH______54302-69C25 £116 + vat
STRUT KIT-FRONT SUSPENSION, LH______54303-69C25 £116 + vat
STRUT KIT-REAR SUSPENSION, RH______55302-69C25 £116 + vat
STRUT KIT-REAR SUSPENSION, LH______55303-69C25 £116 + vat
Front Ornament (P Badge) 10/90 -10/92 62311 62892-62C00
Front Ornament 10/92 - 01/93 62311 62892-73C00
Front Ornament 01/93 - 62311 62892-73C60
Rear Air Spoiler Assy-Roof 10/90 - KH3 96030R 96030-54C25
Rear Air Spoiler Assy-Roof 10/90 - AJ4 96030R 96030-54C26
Rear Air Spoiler Assy-Roof 10/90 - 05/94 TJ1 96030R 96030-54C27
Rear Air Spoiler Assy-Roof 10/90 - 10/92 KJ7 96030R 96030-54C28
Rear Air Spoiler Assy-Roof 10/90 - 531 96030R 96030-54C85
Rear Air Spoiler Assy-Roof 10/92 - FM0 96030R 96030-54C27
Tow Hole Cover 10/90 - AJ4 62228 62228-54C00
Tow Hole Cover 10/90 - KH3 62228 62228-54C02
Tow Hole Cover 10/90 - TJ1 62228 62228-54C03
Tow Hole Cover 10/90 - KJ7 62228 62228-54C04
Tow Hole Cover 10/90 - 531 62228 62228-54C05
Tow Hole Cover 10/92 - FM0 62228 62228-74C02
Front Bumper (Fascia Kit) 10/90 - 05/92 AJ4, KJ7, 531 62650S 62022-54C25
Front Bumper (Fascia Kit) 10/90 - 05/92 KH3, TJ1 62650S 62022-54C26
Bonnet (No ventts just Holes) All All 65100 65100-653C0
Bonnet ventt Main (Air Intake) All All 65815 65852-54C00
Bonnet vent (Louver) RH 10/90 - AJ4 65810J 65832-54C00
Bonnet vent (Louver) RH 10/90 - KH3 65810J 65832-54C02
Bonnet vent (Louver) RH 10/90 - TJ1 65810J 65832-54C03
Bonnet vent (Louver) RH 10/90 - 10/92 KJ7 65810J 65832-54C04
Bonnet vent (Louver) RH 10/90 - 531 65810J 65832-54C05
Bonnet vent (Louver) RH 10/92 - FM0 65810J 65832-54C08
Bonnet vent (Louver) LH 10/90 - AJ4 65811J 65833-54C00
Bonnet vent (Louver) LH 10/90 - KH3 65811J 65833-54C02
Bonnet vent (Louver) LH 10/90 - TJ1 65811J 65833-54C03
Bonnet vent (Louver) LH 10/90 - 10/92 KJ7 65811J 65833-54C04
Bonnet vent (Louver) LH 10/90 - 531 65811J 65833-54C05
Bonnet vent (Louver) LH 10/92 - FM0 65811J 65833-54C08
Front Grille Kit 10/90 - AJ4 62301 62310-54C25
Front Grille Kit 10/90 - KH3 62301 62310-54C27
Front Grille Kit 10/90 - TJ1 62301 62310-54C28
Front Grille Kit 10/90 - KJ7 62301 62310-54C29
Front Grille Kit 10/90 - 531 62301 62310-54C91
Rear Number Plate surround 10/90 - 05/92 90810M 90810-62C10
Rear Number Plate surround 05/92 - 90810M 90810-62C00
Rear Bumper (Fascia Kit) 10/90 - 05/92 All 85010S 85022-50C25
Rear Bumper (Fascia Kit) 10/92 - All 85010S 85022-50C26
Rear Window (Glass) All All 90313 90300-50C01
Air Filter element replacement All All 16546 16546-V0100
Air Filter (Air Box) All All 16500 16500-54C10
MAF (Mass Air Flow Meter) All All 22680 22680-54C00
Radiator Assem All All 21400 21410-63C00
Radiator Hose (Lower) All All 21503 21503-54C01
Radiator Hose (Upper) All All 21501 21501-54C00
Front Strut Kit (RH) - No ABS 10/90 - 05/92 All 54302K 54302-69C25
Front Strut Kit (RH) - With ABS 10/90 - 05/92 All 54302K 54302-69C26
Front Strut Kit (RH) - No ABS 05/92 - All 54302K 54302-69C27
Front Strut Kit (RH) - With ABS 05/92 - All 54302K 54302-69C28
Front Strut Kit (LH) - No ABS 10/90 - 05/92 All 54303K 54303-69C25
Front Strut Kit (LH) - With ABS 10/90 - 05/92 All 54303K 54303-69C26
Front Strut Kit (LH) - No ABS 05/92 - All 54303K 54303-69C27
Front Strut Kit (LH) - With ABS 05/92 - All 54303K 54303-69C28
Rear Stabilizer All All 56230 56230-69C00
Rear Strut Kit (RH) All All 55302K 55302-59C25
Rear Strut Kit (LH) All All 55303K 55303-69C25
Brake Rotor Disc (Front) All All 40207 40206-54C01
Front Wheel Bearing (NSK) All All 40210 40210-50Y00
Front Wheel Bearing (NTN) All All 40210 40210-50Y05
Prop Shaft Assy All All 37000 37000-54C05
Clutch Slave Cylinder Kit All All 30620 30620-80E20
Clutch Tube Assy (MastertoSlave) All All 30650 30850-63C00
Clutch Release Bearing All All 30502 30502-0W720
Clutch Master Cylinder Kit All All 30610 30610-63C52
Clutch Fluid Reservoir (inc Braket) All All 30609 30617-63C00
Transfer Assembley All All 32010M 32010-54C18
Front Differential All All 38711 38411-56E00
Bearing - Diff Side All All 38440N 38440-56E00
Front Driveshaft Kit (LH) (No ABS) All All 39101 39101-63Y01
Front Driveshaft Kit (LH) (With ABS) All All 39101 39101-63Y11
Front Driveshaft Kit (RH) (No ABS) All All 39100M 39100-63Y01
Front Driveshaft Kit (RH) (With ABS) All All 39100M 39100-63Y11
Power Steering Pump Kit All All 49110 49110-54C00
Side Skirt End Cap (RH) All All 76856-50C00
Side Skirt End Cap (LH) All All 76857-50C00
Umbrella is 96546-76M00
Heater Control lightbulb - 25196-89905 - £3.20 +vat each
Thermostat 21200-53J00 £13.90+vat
oil pressure sender V507032J00 £69.90
oil seal on the back of the transfer box (prop shaft)
3314256E00 £12.30 + vat
drop resistor part no 22698 54c00 £81 inc vat
Overhaul Gasket set 10101 - 54C26
Valve stem oil seals------N13207D4201 and N1320753F00 £2.90 each
Cylinder head bolts------11056-54C00 £4.70 each
Inlet manifold gasket----16175-54c00 £4.40
Exhaust manifold gasket---14036-53j00 £14.90
main bearings----12207-54c00 £8.70 each(pair)
Crank thrust washer---12280-60j00 £9.70 set
front crank seal---13510-v7200 £5.40
rear crank seal----12279-18v00 £19.50
Pulley Belt - Water Pump/Power Steering, Nissan, 11950 54C00, Bosch 4PK920 or 4PK919
Pulley Belt - Alternator (No A/C), Nissan, AY140-40830, Bosch 5PK835 or 4PK830
Pulley Belt - Alternator/Air Conditioner, Nissan, 11920 53J00, Bosch 6PK 1035
Standard clutch plate - 30100-79E14
Heater Control illumination:
QTY Req' Unit Price
N2486035F01 N/STK SOCKET & BULB A 1 £4.30
N2754550J00 N/STK LAMP ASSY-HEATE 2 £4.30
N2754550J05 N/STK LAMP ASSY-HEATE 1 £4.30
Aerial Mast*
28215-69C00*
Alternator*
23100-64J00
Badge - GTIR*
90896-50C08*
Badge - P*
62892-50C00*
CV Boot Kit (Pair)*
48203-53Y25*
CV Boot Kit (Drivers Inside)
39741-55E28*
CV Boot Kit (Drivers Outside)
39241-63Y25*
Clutch Fork Boot*
30542-03E10*
Clutch Master Cylinder Kit*
30611-2T025*
Clutch Slave Cylinder*
30620-80E61**
Coil (Ignition)
22433-55S10*
Coil Transistor
22433-53J20*
Fan Resistor*
N2715-00W014*
Fuel Cap*
17251-J7600
Fuel Filter*(Without ABS)
16400-41B05*
Fuel Filter*(With ABS)
16400-53J10*
Gasket (Metal) Turbo to Dump Pipe*
15208-53J00*
Gasket - Engine Kit**
10101-54C26*
Gasket - Manifold (Throttle Bodies)*
14035-54C00*
Gearbox Boot Strike Rod*
32859-03E01*
Ignition Leads*
22450-53J88*
Ignitor Pack / Power transistor / Ignition Amplifier*
22020-53J20*
Injectors*(Nismo)
555cc: 16600-RR420
600cc: 16600-RRR60*
Key - Blank*
KEY00-00118*
Control Arm*(NSF)
54501-69C60*
Oil 7.5w-30 (5 litres)*
10114-J9000*
Oil Filter*
15208-53J00*
Oil Pressure Regulator Kit*
15132-54C01*
Power Rack & Pinion Boots Kit*
48204-53Y25 & 48203-53Y25*
Radiator Cap*
21430-J7000 *
Radiator Hose - Lower *
21503 54C01*
Radiator Hose - Upper*
21501-54C00*
Restrictor Hose*
22320-54C00*
Rocker Cover Spark Plug Rings*
13270-53J13*
Spare Wheel Bolt*
74810-50A00*
Spark Plugs*- NGK (Platinum)*
PFR7B-9*
Spark Plugs*- NGK (Iridium)*
BKR7EIX-11
Sump Plug Washer *
15193-P9000*
Tailgate Hinges*
90400-50C00*
Thrust Bearing*(Clutch)
30502-1W720 *
Timing Chain
13028-53J03*
Water Pump*
21010-54C00*
Water Temp Sensor (Engine Coolant)*
22630-5E02
Wheel Bearings*(N14)
40210-50Y00*
Windscreen Mould*
72761-50C20*
Hub unit 402202-50y10 £125.00
front hub seal 40232-50y10 £5.00
dust seal 40227-50y10 £5.00
front wheel bearing 40210-50y05 £35.00
BRAKE COOOLING DUCT PART NUMBER 63823-54C00
GASKET-EXHAUST ________2069158E01 £2.90 elbow to downpipe
Glass Window runner rubber Drivers side 80330-50C61
Clutch Master Cylinder= 3061054c50 =£74.60 +vat
Front Caliper Seal kit : 41120-11L27
Rear Caliper Seal Kit : 44120-61E26
QTY Req' Unit Price
Aerial Mast*
28215-69C00*
Alternator*
23100-64J00
Badge - GTIR*
90896-50C08*
Badge - P*
62892-50C00*
CV Boot Kit (Pair)*
48203-53Y25*
39741-55E28*
39241-63Y25*
Clutch Fork Boot*
30542-03E10*
30611-2T025*
30620-80E61**
Coil (Ignition)
22433-55S10*
Coil Transistor
22433-53J20*
Fan Resistor*
N2715-00W014*
Fuel Cap*
17251-J7600
16400-41B05*
16400-53J10*
15208-53J00*
10101-54C26*
14035-54C00*
32859-03E01*
Ignition Leads*
22450-53J88*
22020-53J20*
Injectors*(Nismo)
555cc: 16600-RR420
600cc: 16600-RRR60*
Key - Blank*
KEY00-00118*
Control Arm*(NSF)
54501-69C60*
10114-J9000*
Oil Filter*
15208-53J00*
15132-54C01*
Radiator Cap*
21430-J7000 *
21503 54C01*
21501-54C00*
Restrictor Hose*
22320-54C00*
13270-53J13*
Spare Wheel Bolt*
74810-50A00*
PFR7B-9*
BKR7EIX-11
Sump Plug Washer *
15193-P9000*
Tailgate Hinges*
90400-50C00*
30502-1W720 *
Timing Chain
13028-53J03*
Water Pump*
21010-54C00*
22630-5E02
40210-50Y00*
Windscreen Mould*
72761-50C20*
