Mr Gee
Hi guys -
My first post - Just bought myself a nice modified R and I seem to have an idle problem (along with everyone else).
I was gong to attmpt the suggestion below, but I am unable to identify the Idle Valve Connector harness, due to the fact that components have been moved around a bit in my engine bay. I do have a diagram but cannot make heads or tails of it.
Can anyone post a real picture, with an arrow pointing to the correct harness. - many thanks -
Mr Gee
You can adjust the idle in the following way.
Run the engine up to operating temp.
Switch the engine off
Disconect the idle valve connector
Start the engine and ajust the idle screw in the valve (you can only do 1/4 of a turn at a time) to desired engine speed.
Switch off engine and reconnect the conector.
Start engine should now be ok?
That's what i do and it all ways works.
Most of the nissan engine idle systems work in the same way.
_________________
Innovate Performance
Mr Gee
_________________
