I'm having "fun un games" with my car at the moment and am trying to illuminate various components as being faulty, one of the things is the Power FC Pro.
All was fine until I installed a new turbo over last week, once all installed I started the car and the car idled fine.
It was recommended to me that I let the Power FC do it's self learning process again. So I let the car idle for 10 mins then turned on the heated rear window and let it idle for a further 10 mins, then turned off the ignition and restarted it. From that point on the car has idled at such low rpm it almost dies, it really struggles to stay alive.
Funny thing is that when idling at this low rpm it stinks of fuel and produces a lot of black (unburned fuel) smoke from the tail pipe. Now with the symptoms described you would normally say there's a leak in a induction pipe joint somewhere but if this was the case then the car wouldn't drive, and it does, very rich but it drives ok and makes boost.
Anyway still investigating the possible causes but one of the things I was wondering was if you can do a hard reset on the Power FC so all things return to factory settings or is it just a case of installing the default factory map.
Steve
Steve
