How do i install/select different injectors to my power fc pro? can i do this using the commander? or do i need a laptop and the datalogic software?
Also am i right thinking the base ignition timing for a pulsar is 20 degrees? if so is this at idle? then changes as u rev it? the reason i ask is because on the comander im viewing the ignition timing display and it reads 27 degrees on idle should i adjust the dizzy so i get 20 degrees on the comander?
any help on this would be appreciated.
