olidaviesuk
Hi All,
Was thinking of buying this then I found out it was being sold for £100 :?
after having a look at the pics all it seems to be is:
2 x Female Threaded Metal (ballrace) balljoints,
2 x Connection Bars with a chamfuer machined on one end (exactly the same as the old trackrod spline that fits to the hub)
4 x Nylox nuts and Washers,
Without all the technical jargon essentially this lowers the position of the trackrods and also removes all play hence reducing bumpsteer......
So these should cost:
2 x Aurora balljoints (ballrace) - £11 each
2 x Connection bars - about £10 each from your happy local enginnering shop.
4 x Nuts & washers - £1
So gives you a total of about - £43
Am I missing something important.......................? :?
Also if someones got the kit (and its not on the car) if you could give me some measurements of the connection bars......
Might be worth getting a batch made if the savings are worth it ?
