Matt Evans
Hi all! I've been trying for weeks now to find the problem with my mothers 'K' reg. Primera. Its a 2.0 single point injection, and its running like a bag of poo! It used to start playing up after it warmed up. It would splutter and not rev, and I found the more I tried to floor it the less it would want to go. If I took my foot off the throttle a little and feathered it lightly it would try to go but the revs would just climb then drop-off constantly. The problem has now got so bad that it does it more or less all the time, warm or cold. If I try to hold the revs at say 3k, the needle tries to get there then drops off again, then back up, then back down etc. Plus if I try and put my foot to the floor it'll only rev to about 3k, but if I pump the throttle lightly it'll gradually make its way higher, albeit still fluxuating badly.
I ran a fault code and it came up with 21, ignition signal circuit. Its had new plugs, leads are fairly new and are fine, cap and rotor arm are fairly new and are fine, I changed the whole throttle body and its still the same, plus I also tried the coil pack, power pack etc from my GTiR and its still playing up!
Somebody please help!!!
Oh yes, I also bypassed the fuel filter, and I'm now thinking of changing the pump, but if its the pump it wouldn't be code 21 would it?
