Quaife box nosie
Thor
hi,
i have bought a used quaife box.
1.) now after i´ve fit them into my car it makes noise in drive which the same as i drive back. is it correct that it is louder than originals?
2.) so than when i turn the 1. gear and let come the clutch (os giken) the car jerk and in all other gears it is a very good feeling...
anybody can tell me if it is all ok??
Sascha
i think its fooked! why not take it out and sell it to me:twisted: :) il make it all better again:twisted:
I too have an OS Giken clutch with a Quaife.
1. Yes, it whines like a cheap ho'.
2. Yep, mine judders a bit when pulling away in 1st too.
rossdj1983 said:
with labour,roughly how much is a quaife box fitted?
It could be as little as £1900 if your standard box is in mint condition or as much as £3000+ if you need all the parts replacing, Plus taking the old one out and re fitting will add another £300+.
So it's not a cheap buy fella and will probably cost more than most gtir's are worth these days :cry: ...
Thor
why judders the box with the clutch??? have you a idea??
Sascha
I'm guessing the lightened flywheel. Every car that I've had a lightened flywheel in has had a bit of clutch judder.
Perhaps I'm just a little unlucky.
Thor
yes i believe them.. so with the original gearbox the clutch and flywheel was ok and no judder. so after my clutch was in the teath damage i had a feel with judder it was the same as now. is it possible that the judder comes from diff too???
Thor
i don´t know where is the different between original gearbox and quaife box because the clutch i had used before too! there was no judder when i would start to drive..
