when i turn off the ignition the red light on the ecu stays on and the green relay near the ecu clicks and the boost seloniod on the inlet support bracket clicks but if u take the room lamp fuse out it goes out and the other things stop clicking but when the fuse is out the car wont start.
i have done a fualt code check and it flashes 55.
when u start the car the light goes out on the ecu and there is no clicking from the relay
also the car ticks over at abput 1200 but if the car is all ready running u can take out the room lamp fuse and the tick over drops to 900 or so rpm
any help would be much appreciated
