Unfortunately the time has come to part with my R. Its been my pride and joy for so many years
http://www.gtiroc.com/index.php?threads/my-project-r.55084/
Open to sensible offers
L reg 93 Jap import, heavily modified.
Its currently not running as a result of an incident in the dark trying to jump start her, unfortunately battery terminals were crossed and the Apexi FC does not appear to respond. I haven't investigated this any further due to lack of time with two young children. It might be a simple fix for Apexi, I don't know. I had thought about going down the FuelTech route and removing the AFM.
Spec is as follows
Engine:
Chemically cleaned & crack tested
Tomei 270deg high lift procams
JUN Titanium double valve springs
JUN Titanium valve retainers
JUN Valve guides
GReddy rocker arm stoppers
Valves re-cut / 3 angle
Port and polish gas flowed head
AeroSpeed adjustable cam gears
HKS head gasket
ARP head bolts
ARP main stud kit
Nissan gasket kit
87mm JE Pistons and rings
Pauter X-beam rods with EDM drilling
ACL calico coated race bearings all round
Nissan water pump
Nissan oil pump
Nissan oil pan
Nissan timing chain/guide/tension kit
Lightened and balanced crank
Drive Train:
OS Giken R2CD clutch and flywheel
Quaife gear set
Electronics:
Apexi Power FC (potentially dead)
Apexi AVCR
Apexi Commander (gen2)
Fuelling:
Walbro fuel pump
RC 1000cc injectors
SciTech fuel filter (not fitted)
Cooling/intake/exhaust:
Garrett GTX-3076 turbo (billet steel turbine)
Protech (custom made) T3 tubular manifold (this is truly stunning see pics on 'my R thread (link above))
Protech (custom made) down pipe (ceramic coated) - waste gate feeds back into exhaust - see pics on 'my R thread (link above)
Tial 45mm external waste gate
Full 3" stainless exhaust (V-bands) with 5Zigen muffler
FMIC with 3" pipework from intercooler to plenum
HKS blow off valve attached to induction pipework
19 row Mocal oil cooler – top mount
S/S braided oil lines
Mocal thermostatic sandwich plate
Koyo rad
2x 11” front mounted slim line rad fans
Adjustable thermostatic fan controller
Nismo thermostat
Z32 MAF
ITG air filter
PTFE TB to block gasket
Handling/braking:
Powerflex front wishbone bushes
Powerflex engine mounts
Whiteline anti-dive kit
Whiteline ARB (front & back)+ bushes
Uprated rear subframe poly bushes
Uprated drop links
Cusco front strut brace
GAB rear strut brace
Tein super street coilovers
Hi-Spec front brakes (300mm IRC)
Custom made s/s braided brake lines front
Goodridge s/s braided brake lines rear
Nismo long hub bolts all round
Toyo T1Rs all round
New front lower ball joints
New track rod ends
New front wheel bearings
Other mods:
Auto choke removed
ABS removed + brake lines modified
Aircon removed
All plenum and T/B mods
Custom oil separator, feeds back to sump
Braided clutch line
Battery to boot
Rear seats removed
A-pillar pod with boost and FPR (cheap gauges)
Standard boost gauge replaced with EGT gauge
New Cat 1 Alarm
Cosmetics:
Kream wide arch kit (plus bumpers) - Not fitted (arches have been welded and fillered with these being planned to go on)
All engine mount brackets, wishbones + cups, ARB brackets powder coated
Rear sub-frame powder coated
OZ 16” alloys powder coated (white)
Engine bay resprayed
Stripped, zinc primed, painted and under sealed arches
Rear Samco’s
All blue/black silicon hoses in engine bay
Most brackets and catches zinc plated
Laguna front splitter
Quaife has been well looked after with periodic rebuilds/checks when the engine has been out.
Stacks and stacks of receipts
Last map reached 438bhp
I also have a spare engine (head has been taken apart for shims) and broken gearbox (3rd split). Also an MSD blaster kit
Loads of spares which I'll have to list separately
I don't mind selling the spares separately but would rather sell the car as is, I don't have the time to break it unfortunately and could do with the space in the garage.
This car has been a passion of mine for years. Primarily focussed on everything but aesthetics which were planned to be one of the last jobs but unfortunately its time to sell up.
Anyone who has the time to sort the ECU and aesthetics will be very happy with this car, I'll miss this rocket ship...
Cheers,
Jon
Spec is as follows
Engine:
JUN Valve guides
HKS head gasket
ARP head bolts
ARP main stud kit
Nissan gasket kit
Nissan water pump
Nissan oil pump
Nissan oil pan
Drive Train:
Quaife gear set
Electronics:
Apexi AVCR
Fuelling:
Walbro fuel pump
RC 1000cc injectors
Koyo rad
Nismo thermostat
Z32 MAF
ITG air filter
Handling/braking:
Uprated drop links
Toyo T1Rs all round
New track rod ends
Other mods:
Auto choke removed
Aircon removed
Braided clutch line
Battery to boot
Rear seats removed
New Cat 1 Alarm
Cosmetics:
Rear Samco’s
Cheers,
Jon
