It's an easy enough job fella, But two of the bolts will most defiantly break on you, So you will need a drill to drill out the broken bits and be ready with 2 new nuts and bolts.
you will need to take out the head light and front indicator because their is a couple of bolts behind there, And the front bumper is bolted to the wing and the front of the wheel arch, Then you the 5 or 6 bolts along the top of the wing and 2 in the door shut that you will need to get to with the door open.
The two that will probably break are at the very bottom where it bolts to the sill under the car.
You will need to remove the side skirt as well, because this covers the bottom of the wing, And the wheel arch liners will also need removing as well.
And don't forget to remove the indicator from the wing as well.
