The car is standard apart from the zigen exhaust & apexi filter. The temprature is ok driving easy or even cruising at 140KPH with the A/C on.But once you accelarate hard (slugishly) the temperature rises inntantly,get off boost while cruising and it cools to the normal temperature This happens mostly midday when temperature approaches "50deg centigrade"
Tried remedies removed the thermostate no improvement
installed a localy custom fabricated 3row copper radiator still no improvement.
The thought of front mounted IC well that is out of the question.
And yes checked both fans are funtioning,no leaking coolant
and using 98otane unleaded.
