hi Sacha,
I would think that any good assembly lube would be good enough.
make sure you cover everythingl and not use too little.
If the engine is having problems getting oil pressure at the start then you could remove the cam cover and use more lube on the cam lobes and followers so that you don't have any problems.
If the spark plugs are out then you shouldn't have any problems with the bottom end.
