My GTiR is running a really rough idle, sounds like a ported rotary. I thought that fuel injected engines should idle with no problems
Unfortunately there's no guarantee that the second hand one is working, the could both have faults. Have you tried the maf grounding fix?gidoink said:Its coming up with fault code 12 so i bought a secondhand air flow meter but, made no difference
If its an help mine had the same fault code and I replaced the AFM but it still came up with the same code after The actual code if is AFM and/or electrical wiring fault I think :?:Its coming up with fault code 12 so i bought a secondhand air flow meter but, made no difference as it is still coming up with the same code
Jasegould said:Fast Guy, does the manual give any info on fault code 12 :?:
