After having a few coolant leak/overheating issues (from split hose) the past week and fixing it all and did a full coolant system flush the car is now running like complete shit.
On idle it misfires quite aggressively and while driving its not much better. The only other things I tampered with recently was fitting a slightly larger cone filter (required me to unplug the MAF to get it out and fit new reducer part for cone) and the vacuum set up.
With the vacuum's all I did was replace the overly long/worn out hoses with better newer ones and there was one that wasn't even plumbed into anything but I followed the diagram on here and set it all back up.
It had the plugs and oil changed a month or so ago but will be doing it again soon for winter.
Also considering giving it a compression test later to rule out anything else.
Just did a fault code check and came up with 55 (so nothing).
I'm out of idea's it ran fine when bleeding out the system it was only after I changed the vacuums and unplugged (then pugged back in) the MAF.
Any help appreciated!
