B
beastgtir
Right lads, bit of a problem now.
Ive got an apexi avcr (boost controller) and a apexi safc.
When i change the settings on the boost controller. there is 2 settings.
A) 0.4bar boost
B) 0.9bar boost
i usually never run it on setting B, even if i do, the car is lovely and drives 100per cent spot on.
The problem is with setting A, when im driving it on setting A and i come to some private land to test the 0-60, in 1st gear giving it a bit of stick, the car smokes ever so lightly, its a very faint blue smoke.
As soon as its in 2nd gear there is no smoke at all and 3rd/4th/5th is great too.
On setting B, there is no smoke is any gear, even at full throttle in 1st..
Any suggested recommendations?
Im thinking the safc is set up to run with the 0.9bar boost and when im running 0.4 its running slightly rich.
I am planning on getting the car (apexi's) mapped,dyno'd and set-up by powerstation in tewksbury.
Is my trouble with the apexis, or is there a leak somewhere in the seals or pipes?
Thanks, Beasty
A) 0.4bar boost
B) 0.9bar boost
Thanks, Beasty
