Looking into whels and brakes and seems most require spacers due to the offset. Would you be able to get away with just running spacers for say 5-10mm or would you need to extend the bolts?
They are easy to change. Once you get the disc off it will be blantently obvious that all you got to do is whack the studs with a hammer and they fall out. to get the new ones in you need to line up the spline and use a nut to draw it in.
