Hi,
I coded launch control for GTIR few 2 years ago; here is the XDF:
www.skizoproduction.com/GTIR_LAUNCH_CONTROL_NO_RETARD.rar
www.skizoproduction.com/GTIR_LAUNCH_CONTROL_WITH_TIMING_RETARD.rar
You need to use my modified bin inside the rar then modify it using tunerpro and the xdf. It wont work if you edit the stock bin.
Fan temp control:
I posted disassembled bin and explained how to do it, but i think people will be more happy with this simple xdf:
www.skizoproduction.com/GTIR_FAN_TEMP_CONTROL.xdf
Fan temp control: You edit any bin (stock, or my modified one with LC).
Fan control temperature on stock software;
IF TEMP REACH 95 degree when the car is moving then FAN START at LOW SPEED
IF TEMP REACH 95 degree when car is not moving then FAN START at MAX SPEED
In the XDF, you have 4 step of temperature.
1A 1B = 90degree (FAN STOP)
2A 2B = 95degree (FAN START LOW SPEED)
3A 3B = 100DEGREE (FAN START MAX SPEED)
4A 4B = 105degree (FAN START MAX SPEED AND AC IS SET TO OFF)
To make your FAN START at 85 DEGREE, JUSTE SUBSTRACE 10 to ALL THE VALUE, IT SHOULD BE LIKE THIS:
1A 1B = 80degree (FAN STOP)
2A 2B = 85degree (FAN START LOW SPEED)
3A 3B = 90DEGREE (FAN START MAX SPEED)
4A 4B = 95degree (FAN START MAX SPEED AND AC IS SET TO OFF)
Thanks you and please share your knoweldge.
Tom
Fan temp control:
Tom
