Hi there,
just a couple of questions about the super afr and some situations that have and will come up over the weekend due to power and fuelling.
Does the super AFR loose its memory if the battery is disconnected for any great length of time? :?
battery died last week and was replaced, not really super dead, but flat enought to not be able to turn the ignition over, and loose my radio channels.
I have herd tell that the afr should be set at up to +6% fueling for one bar (at peak point) but mine and runs at +1-2% from 3000rpm upwards and barely gets above +3% ...at peak . :shock:
reason i ask, is cause i am changing the fuel filter tomorrow and if this lets more fuel flow, am i likely to do any damage... Car has other problems like the knock sensor fault code, but as the boost is set to 1.1 bar i am worried that if the fuelling goes out i could have major and expensive engine probs.. :?
so three questions really
1) under what curcumstances does the S-afr forget its fuelling settings?having been properly set up by Ian at hi-tec, not more than 12 months ago
2) what should it be reading (its hidden in the glove box so i cant see it most of the time) when running just over a bar of boost?
3) will the engine die if it gets too much fuel, or will it just drink and be merry?
you guys always seem to be able to make sense of what i write, so if any more info is needed shout.
thanks heaps
thanks heaps
