yes, I have. I replaced the rubbers for new ones. As you've probably worked out the glass is glued into metal surround with a black Sikoflex type glue.
The rubbers you can see surrounding the glass at the moment are a T section with the tail of the T embedded in the glue, it's the metal strips inside the plastic corners that are a pain to get out. You need to cut the top off the T section rubber then use a special hook shaped knife tool to push into the glue and then carefully under the glass and then work it round the window.
The glass is toughened so it will take a little bit of abuse but take your time and be patient and all will be fine.
Otherwise there is always your friendly autoglass man.
