tein coilovers quicky
turbodaily
:oops: silly question but what way do you winde the coilovers spring adjuster to get lower? is it down to lower, or up? thanks :doh: :p
Down to lower, up to raise.
IIRC at it highest its still about a 10mm drop. At its lowest its around a 60mm drop
turbodaily
thats what i thought,cheers. got them at the bottom, just thought it could be abit lower at the back. i heard d2 coilovers have more ride height adjustment.
If you go any lower than 60mm drop, you car will handle lile a sledge (but I won't get on my soapbox for a change)
It might be that the springs/car/weight aren't balanced very well, check your ride heights as it might be just one side that is "cocking its backleg" if you see what I mean.
Follow my coilover setup guide sticky.
