SplanK
Hiya guys...
just looking around for stuff to do to the DET engine when i get it..
http://www.ferriday.co.uk/gaskets/gaskets.shtml
Found this company in the uK that makes something called "thermalblock spacers" or gaskets that stop/dramaticly reduce heat transfer..
done a quick search but not foung anything on here...
quick run down
basicly these gasket fit between the engine block and the TB's to dramaticly reduce the intake air temp. On the SR20DE's these make a HUGE difference as they stop heat transfering from the block into the intake...
I was wondering if anybody had these fitted to a GTiR lump and if they had seen any decent gains or at least lower charge temps
They also do the exhaust gaskets which prevent exhaust temps increasing the temp of the block on a tubby engine - which can only be a good thing really...
£80ish for the pair - cant go far wrong with it really
quick run down
