K
krikra
Hit the rev limit in 1st gear and the engine sounded funny. Like only 3 cylinders working.
When I took of rocker cover turned out it was a rocker arm that has jumped of.. Even though I have a rocker arm stopper kit.
Installed JWT S3M cams a month ago and everything has been working well since. Rev limit was set to 7900. Is this to high?
Funny thing is on the rocker guide one of the guide "walls" had broken of. Question is if this happened first causing the rocker arm to slide of the shims...
Has anyone experienced this before - the rocker guide "walls" to break??
Managed to find both the rocker guide and the missing "wall" but I cant find the normal shim....... Maybe I should look in the sump?
