Please lets try and be productive and have a complete tread without reverting to squabbling, pi**taking or sexual insults. Hopefully this tread will benefit us all.
This is a post designed to try help us all to find the Ultimate Turbo upgrade and mods necessary for an R’ used as an 340 - 360bhp every day driver. The car will not be used on the strip or used on track days but will be driven hard and used as a fast road car only. I'm going to base this on the mods I've already done and planing to do to my R' as ultimately this is what I want to achieve.
I choose the 340 - 360bhp as this seems to be the upper power limit of a good condition, looked after or reconditioned standard gearbox if treated sympathetically (No 6k Launches).
Heres a list of the mods on the car to date
17" Lenso S7 Alloys
Godspeed 325 disk/4 pot front brake Kit
Godspeed 285 drilled/groved rear disks
Goodridge Steel braided flexi brake lines
Hiteq 30mm lowering springs on std shocks
Mocal 15 bar Thermostatic Oil cooler
Skyline R32 Front mount Intercooler
Custom 2 3/4" pipe run for above
K & N 57i Inlet Filter
Stainless Inlet Hard Pipe to move inlet behind light
Moved battery
Removed air con
HKS inlet/Exhuast 264 cams
Full Turbo back Mongoose
Walbro 225lpm Fuel pump
Cusco Upper front strut brace
Cusco Lower 4 point Strut brace
HKS Cerimetalic 4 paddle clutch
Lightened and Balanced Std Flywheel
Turbo Dynamics MD214S rollerbearing Turbo
Dawes Device set @ 1.25 bar boost
Planed Mods to add to and replace some of the above mods (ETO - March / April 2004)
New rebuilt engine & head + above HKS 264 cams will be used
(halfway through rebuilding spare engine, everything replaced with new parts, all lightened and balanced e.t.c.)
Arias 86.5mm forged pistons (Ceramic coated crown + slipper coated rings)
600 - 700cc Sard injectors (might be OTT what do you think ? will 550cc be enough)
Apexi Power FC + it’s boost controller
Q45 (90mm) MAF with K & N to suit
Powerstation Anti-bumpsteer kit
Whiteline handling kit (rear anti roll bar)
3" dump pipe / front pipe to first box on the goose
Eventually a Quafe gear set for Gearbox
Now the question is what turbo do I use along with the new planned mods.
My thoughts were a GT2835, 4” inlet and 2” hose fit outlet, with the 56 trim compressor and .86 AR turbine housing, this is the biggest this one comes I think, it’s the pro version apparently.
Or the GT3037 in one of it’s smaller trims, a bit laggy I think and maybe OTT for a Fast road car.
Any opinions on the mods so far and the planned Mods and any other turbo’s spring to mind?
If you were going to add any other mods to aid the cars drivability what would you add ?
17" Lenso S7 Alloys
Moved battery
Removed air con
