me too, just make sure the cups seated properly and chock the rear wheelsGTIR-LOZ said:you can either use the proper jacking points on the sills at the front or use a main supporting bar, one that will not bend etc when in use i have used the main bar at the front before and that seems ok
thats the one i was talking about :lol:geetee said:eerrm... there's a proper jack point under the front centre of the car
http://www.mummachummas.co.uk/gtir/lifting.pdf
You might need to right-click and Save As.... doesn't seem to display right in my browser...
Front one is just a \_/ shaped bit of metal welded onto one of the cross members.
There's been some discussion about it not being wise to lift using the sills.
Graham 8)
