pulsarmad20
Hi All
I have recently screwed my after market bleed valve screw right in to see if i could get standard boost and the answer it no its running 1 bar still.
my problem is i would like to take all the vacum pipes off and re plum them all in as im not sure if all is ok.
I have got the vacum pipe layout printed off but cant get to grips with it.
I have 1 pipe from actuator to bleed valve (bleed valve has 3 nipples) to left nipple then the middle one is blanked off then the right one goes just on the back of the plenum.
Then i have another vacum pipe coming from rear of plenum to a 3 piece that then goes to sensor in the passenger wing and to a aftermarket boost gauge.
My question is how is this mesuring my boost if i only have a pipe from actuator to bleed valve then from there to rear of plenum ??? the boost sensor for the gauges isnt connected to it so what is it mesuring??
sorry if its hard to understand i hope some one can help me.
i could be paniking over nothing but like to make sure.
thanks
sam
thanks
sam
