4mm ,better in rubber than silicon as it is more solid and is less likely to balloon under pressure, it also grips the nipples better. Use small clips or zip ties to secure in place.
i thought you had just had your car re-shelled? I seem to remember seeing a thread somewhere that you car was very Badley damaged from towing.
